ondemandbindery
How about exposure to paper dust? Anyone have much information on that?
John Weaver
John Weaver
John Weaver
No problem; it looks like Solvex doesn't meet you requirements either, MSDS's can be found here: https://www.box.net/shared/1gp2k4ck7xygvbjelk3iThankyou for the response. I have checked the high fidelity fount and it does not meet our requirement. The A+B systems cleaner looks like it will, not sure about the solvex, couldn't find the msds for that product.
High fidelity = 2 Butoxyethanol, ethylene glycol both sara 313 listed.
MSDS On Fileâ„¢
I'm hoping that I can have tests done to find out if I do have the faulty gene..
Anyway back on topic.
I finally recieved a truthfull MSDS for a product that contains CAS# 64742-48-9 (Naphtha petroleum, isoparafin, hydrotreated) A popular chemical in blanket and roller washes
Chronic health effects listed : There has been some concern that this material causes cancer & mutations but there is not enough data to make an assesment
Substance accumulation, in the body may occur and can cause some concern following repeated or long tern occupational exposure.
Constant exposure over long periods to mixed hydrocarbons may produce stupor with diziness, weakness and visual disturbance, weight loss and anaemia, and reduced liver and kidney function. Skin exposure may result in drying and cracking redness of skin.
Chronic exposure to lighter hydrocarbons can cause nerve damage, peripheral neuropthy, bone dysfucntion and psyciatric disorders as well as damage to liver and kidneys.
Does this mean that all companies selling this product that has not listed the full health effects in their MSDS are open for litigation??
Cas # 64742-47-8 Is this chemical safe ? It is said that it is zero VOC, I would think that this is through exemption?
According to this EU Safety it is not to be used as a solvent. It is to be used as a fuel in a closed system.
http://www-static.shell.com/static/...m_hydrotreated_light_cas_64742-47-8_nl_en.pdf
This is an msds sheet of an approved Fogra wash
http://www.towerproducts.com/assets/files/Infinity Wash HMK-2 WM Jan 2011.pdf
Fogra approved a wash that has Cas # 64742-47-8 as an ingredient. While the Safety DATA Sheet states that it is not to be used as a solvent.
Who is telling the truth? How many others are there?
Who are we to trust with our health and well being?
The first section of the Fogra testing
1. Details of the compositions must be supplied to the “Berufsgenos- senschaft Druck und Papierverar- beitung” (Institution for statutory accident insurance and prevention in the printing and paper processing industry) (BG ETEM – BG Energie Textil Elektro Medienerzeugnisse) to enable the health risks to be assessed.
I need say NO MORE>
Specific glycols are used in alcohol reduced / Free fountain solutions, talking to chemical suppliers they are needed to replicate IPA.
Correct me if I'm wrong,Glycols main function would be to reduce the dyne levels of the mixed fountain solution & to act as a solvent to clean the non image area of the plate.
I can see that there has been a very small group of manufacturers, from memory three to four companies that have developed alcohol free fountain solutions that contain zero solvent based glycols, assumed to be run with an ink that has had its properties adjusted to compensate.
Question
How does a non solvent based fountain solution clean the non image area of a plate ?
What has to be changed to the current ink properties to allow a non solvent based fount to work ?
At a gues these fountain solutions would be made up with a mix of surfactants ?
To my knowledge surfactants are used in many roller washes and serve two purposes, one to make it water miscerbal and two a solvent. Looking into surfactants further, the majority are derived from petroleum distillates. Has anyone looked into the envrionmental or health issues that arise from the distilling process ?
Or is it that these particular fountain solutions contain surfactants that are not derived from petrolleum distillates?
Adding to this is ink. A conversation I have had with several ink suppliers when talking about vegetable based inks is that although they are based on vegetable oils instead of petroleum oils, the pigmants are extracted through a petroleum source. So if you are to view it as a cradle to grave - environmental impact, they too have a detrimental impact on the environment & at some stage a health effect on humans who interact with the chemicals in the manufactering process.
Thinking about the chemical PPM levels a bit further. Has anyone ever had someone come in with a tester just to see how high the PPM levels are in your factory, durring peak production?
Our ceiling is so low that if you stand between decks to wash ink ducts up on our 4 colour 52, your head pretty much touches the ceiling. We have zero exhaust extraction fans, just an airconditioning unit, that ensures, it's not just us pressman that are being effected by the harsh chemicals, but the management & office workers too.Would be interesting to find out what the PPM levels get in our factory.
If management thinks that the chemistry is not making it to the offices they are very ignorant. It is no different than second hand smoke.
Second hand fumes are absorbed into all wood,carpet,clothing,shoes, socks. hair,curtains,paper, insulation or any thing that is porous including people. If the facility completely disposes and removes all the chemistry causeing the problem it will be at least a couple of years before the largest portion has dissipated, some odors and smells will never go away.
So management if you think you are insulated from the pressroom chemistry think again.
