Wouldn't this then limit the ability to emulate spot colors or higher saturated printing? Not sure inkjet manufacturers see limiting the gamut to ISO as all that desirable given that the "proofing" market likely isn't as large as say the "photographic" market.
Well, just speculating. Since inkjet usually have more than cmyk inks - what if cmyk were pigments that had a similar spectral composition to ISO - giving the match across different illuminants. Then add 3 ink hues to broaden the gamut to hit the PMS library. Basically the same thing that's done on press with spot color replacement/simulation systems. I know that on press a 7 color inkset will hit some 95% of the PMS library so maybe it would be possible to do the same with inkjet.
Just a thought.
I don't know what the economics are for proofing consumables like ink - but I think they are very, very profitable as they are. If a vendor came out with a better ink set they could probably command an even higher price and hence profit margin.
Given the fact that vendors haven't been able to figure out a take up spool so that the prints aren't just dumped on the floor - the technical challenges must be very difficult.
best, gordon p
