kdw75, you've heard the expression, "You get what you pay for." i1 Publish Pro 2 will be a more robust solution, but you have other issues in play.
Do you know if the drivers are CMYK or RGB?
An external RIP would make your world a lot nicer to live in. By not paying for an external RIP, you pay for it over and over and over and ...
There are two issues. The spectro hardware and the software. The Munki is very good hardware. I have compared monitor profiling results on an Eizo against the i1 Pro and they produce close to the same profile (even though the Munki is UV filtered and the i1 was uncut). The Munki only has a limited range of support for X-Rite and third party software (in many cases only the Munki software). For making printer profiles, AFAIK you only have the Munki software, the charts contain huge patches for hand strip reading and they use a limited amount of patches (more interpolated values). That being said most reviews of the profiles it creates state that they are good considering what the system has to work with. I have not seen or performed tests comparing the two devices (we have both). The i1 has a far, far greater range of free and commercial X-Rite and third party software support.
I am still concerned with the variable output nature of these devices and the unknown calibration support. If the devices are not stable and if you can't calibrate back to a repeatable known state, then you mayl be making profiles at daily. If I was going to be making profiles daily, I would prefer to use an automated solution for reading charts. The appeal of the Munki in this situations is that you don't have to read a lot of patches, which may be both a blessing and a curse.
