This printer is great for engraving/embroidery shops or sign shops.
Also a great opportunity to start your own small business. Print any artwork or personalization on
any product up to 4.5" high.
RETAILS FOR $31,995 + SHIPPING.
We are offering it for $18,995!
Compress LED UV technology is an entirely new small footprint flatbed UV printer that brings cost-effective, on-demand color printing to the production floor for a multitude of substrates. The Compress iUV600s gives you the freedom to print exactly what you want, when you want and virtually to whatever you want. Fast color digital printing is possible for glass, metal, plastics, board stocks, acrylic and more. Even flexible medias like textiles and Leather deliver the widest flexibility in commercial printing options. The Compress iUV600s flexibility means reduced waste, less inventory, accelerated workflow, full color process printing to a multitude of substrates with variable data imprinting - attract new business and customers or solve current production issues.
The Compress iUV600s industrial print head features 1440 nozzles capable of delivering a minimum picolitre drop of just 3.5Ng for ultra fine dot placement. When configured with up to 6 colors of CMYK - White and Clear our 604mm wide print width delivers 1400 dpi native print resolutions at incredible speed with remarkable color brilliance. Max print area is 604mm x 450mm (A2+) with an adjustable media height to 285mm (the largest media height of any printer in its class). Speeds up to 100 feet per hour in production mode and 50 feet per hour in quality mode. Each ink color is delivered via a 250ml pressurized ink tank for constant ink feed to the damper. All white Inks are pressurized and recirculated with filtering by our patent pending WIMS (white ink management system) for less downtime and ink issues in general... Low maintenance. Production ready.
Features:
-Six independent color channels
-604 x 450mm print area with 285mm media height.
-Optional unwind/rewind for roll media
-WIMS white ink management onboard
-All steel construction
-Dual LED variable watt low heat lamps
-Inbuilt media height detection
-Ink mist extraction
https://www.youtube.com/watch?v=xZAEkUA3ARc
