Convert PDF RGB images to CMYK with ink coverage 240%
Kenhew
Can some one show me how to convert images ONLY (NOT TEXT) to cmyk with ink coverage to 240%. I try many difference way but wont work. Do you did i can USE Preflight to change some EDIT and make it work. Most of the time i just edit image and open with Photoshop and color correct it but too much work and sometime color not consitant.
Thank
The correct way is to use Pitstop Professional plugin for Acrobat Professional.. This is an easy and fast solution. You can program a set of Global profiles to do what you need.
Use the rainbow colured colour converter
In acrobat 9 you can specify what you want to convert and how. RGB images to a specific CMYK profile is fine. I usually just convert all to output intent preserving blacks and pure colour, love it, does for me exactly what I want provided I use the correct output intent profile (in your case one with 240% Tac):)
Ken, as the Callas representative in North America I would be happy to provide you a webinar on how to use the built in preflight module in Acrobat Professional. Please contact me and we can set it up for whenever is convenient for you and your department.
there are other conversion systems like gmg colorserver which does a really great job
edwin
