Convert PDF Spot Alternate Colourspace from CMYK to Lab
I have been looking for a way to convert PDF Spot Alternate Colourspace from CMYK to Lab builds.
Both Acrobat’s native preflight and PitStop Pro 12 have the ability to convert from Lab to CMYK, but not the other way.
It in theory should be simple enough to create an action list to select any spot colour and remap it’s colour to the same named colour that uses a Lab based alternate colourspace…however it appears that all of Pantone library files use CMYK and not Lab as the alternate space and there is no Lab alternate colourspace option when creating a new spot inside PitStop Pro 12. I tried importing a .csv setup as Lab values for a named colour, but no dice.
I was attempting to overcome a proofing RIP issue where spot colour overprints were not working correctly in a specific problem file when the referenced spot lookup table in the RIP was Lab based, however if using the alternate colour from the spot in the PDF file (bypassing the RIP lookup table) the overprint was rendered correctly (when the PDF spot colour alternate was set to Lab or CMYK).
A niche case (most wish to remove Lab alternates) with multiple workarounds (such as remapping to another spot colour in the job that is Lab based), however it would have been good to simply remap all spots with CMYK alternate colour builds to Lab alternate colour builds in PitStop.
Hi Stephan
You are correct, we have not yet implemented the Lab versions of the Pantone library in PitStop.
However what might be useful for you to know is that you can import color swatches from Adobe applications into the color database of PitStop, that might be an interesting workaround?
the supported file types you can import into the color databases are:
.ase = Adobe Swatch Exchange
.aco = Adobe Photoshop Swatch
.act = Adobe Color table
Thanks Andrew, I did try .csv… Let me look into using the Adobe Lab based colour library files…
EDIT: Thanks Andrew, this is great, it took little while to ingest the entire Pantone + Coated Lab swatches, however once in this works fine!
