Convert RGB to CMYK, all colors to Black channel
lnivin
We need a CMYK (not grayscale) with all colors moved to the Black channel. Can PitStop do this?
So just to clarify, you want a Black and White job with everything on the K plate, and empty CMY?
Perfect.
It's a two step process.
1. Do a convert to Grayscale.
There's a few ways to do it, Global change 'Convert to Colorspace' and configure it for Grayscale would be one.
2. Then once it's Grayscale and a single black plate, Use the Global Change 'Clean up black' and configure it to only have the option 'Convert Gray to CMYK Black' enabled.
That should do the trick
I suggest first turning off color management, then using the remap color global change and map all to Device Gray.
