Copy Pitstop Paths to Adobe Illustrator or Indesign
assman
After selecting the paths using Pitstop, how do I copy them into Adobe Illustrator or Indesign as I need it to be used as background? Pls advise, thanks in advance.
easier?
easier?
Can't you just open the PDF in illustrator and access the paths there?
Another option would be to use the Edit Object (or Touchup Object) tool in Acrobat itself. Select the object/paths in question and then either double-click to edit directly in Illustrator or right/ctrl-click to get the menu of available options (incl. editing).
