Creeping perfect bound books.
Hoping to get some opinions on the best way to creep a perfect bound book specifically dealing with image crossovers. We've got a good handle on the calculation, but are now trying to compensate for the bend in the book. So if you were to open a book and force it to be flat on a table the crossovers look great. But most readers would open it and allow the natural bend of the pages. In this way the crossovers seem to be off.
Our shop calls this a "visual crossover" situation. If you have a 1/4" hinge score.... On the left-facing page move the image 3/8" to the left. Do the same for the right-facing page moving the image to the right.
The only drawback is that you have to export/print your pages one at a time.
Mac,
We're doing something similar but only needing to use 1/4, but this would be for Inside Cover and page 1. I'm more interested in compensating for "visual crossovers" on say p25 of an 80 page book.
If your are running 16-pg signatures creep is negligible so the same method would apply throughout the book. The reason I use 3/8" instead of 1/4" is to take into account the hinge plus the bend/roll of the page as it is opened. I have found that this works almost perfectly.
Creep is not what we call it. Crossovers are handled individually by subject matter for us. 1/4" hinge score we pull out a standard 1/8" on both left and right hand pages. If the subject is locked (tied to a page element on one of the pages) or would cut off a portion of an image that would be visually a problem, we adjust and may pull one page more and the other less adding up to the 1/4" pull. On IFC/p1 and last page/BC crossovers we pull out 1/4" both ways to clear the hinge score and hold back all inks 3/16" from spine for glue trap. Works for us on most all our perfect bound books, and we do alot of them.
