Cut off
In some presses the cut off is 21.5" which is 546.10 mm and in some it's 546 mm. Is the difference only theoretical or is there a difference of 0.01mm practically.
Heidelberg Harris is 546.1 mm where as Komori is 546 mm. Is the difference only theoretical or is there a difference of 0.01mm practically. Can this folder from Heidelberg Harris be coupled with a Komori of 546mm cut off.
Re - CUT-OFF,
For what reason are you trying to marry a Heidelberg Harris Folder to a Komori Web Press?
Regards, Alois Senefelder
