CreoleCuisine
Can anyone share a video of proper cutting technique?
Let's say you have 24 up business cards with a .25 gutter and a bleed and a Triumph 4850 guillotine cutter.
Would you put the long edge in first or the short edge?
Would you rotate clockwise or counterclockwise?
Do you use the left side or the right side?
do you cut 2 sides to make a perfect 90 degree angle?
do you cut at each increment or cut at all the "bottoms" or "tops" first?
My Ricoh 7500 is pretty darn accurate when it comes to registration but for some reason, my cards don't finish centered. When I lay the stack in the cutter and expect to cut at 17.5", the laser is off a good bit. Which makes the rest of the cuts off.
Is something off if so, what? Is it the printer? Paper? Cutter?
