Dcs 2.0
Dcs 2.0
The most important question is: Are You really want to make preseparated output? If the answer is yes, You found the right format.
The difference between Multiple file and Single file eps is: If You save as Multiple file, You will get 5 separate files (if You work with only CMYK colors): one with .eps and 4 others with .c, .m, .y and .k. (If You have made additional spot channels in Photoshop, You'll get more files with the .channelname).
If You save as Single file, You will get only 1 file with .eps and all of Your colors will be in this one file. But do not forget, this is a separated file inside.
In our old Agfa Apogee rip the Single file with Color Composite (72 pixel/inch) was the best solution (note: it was a separated workflow, not todays ultra/hyper/super modern composit stuff). If Your image is not an ultra resolution stuff, You can use JPEG/maximum quality without any problem, otherwise choose ascii or binary (depends on Your rip).
If You want to use Your DCS 2.0 file in a layout application, it is ok, but
a, in Quark the final output must be separated
b, InDesign can rebuild a composite image from DCS 2.0 if the files were created in Adobe Photoshop.
c, Did You know that still CorelDraw can import DCS 2.0 files?
Best Wishes
TLala
