Diference between bizhub PRO 6501 & bizhub PRO 5501
Denis9595
Can enyone tell me all the diferences between these two machines. In KM office they told me that the print engine is the same, olso toner, the only diference is in speed and in fuser unit. Thanks.
As far as i know the difference is the speed, AND I DON'T THINK YOU CAN GET THE SCANNER/COPIER GLASS WITH THE 5501
Differences
Differences
So only speed is different and the finishing options that can be used.
The embedded EFI controller will not be able to support al finishing options.
So the questions is, what doe you want to produce?
Then select the appropiated engine and controller.
