Digifold Pro Problem
Damo @ CA
Hi, when we purchased our Digifold pro a number years ago the installing engineer told us not to press the compressor switch and system switch at the same time because this could cause the fuse in the plug to blow intermitently.
Now the fuse is blowing intermitantly when we press the compressor switch on its own, does ayone else have this problem or has had this problem fixed.
Had the same problem many years ago. Canon technician was in at the time and suggested I use slow-blow fuses. Haven't had a problem since.
thanks for the reply but its not the fuses in the machine its the actual 13A fuse in the plug. Can you get slow blow 13A fuses for plugs?
