I have a Dolev 800 circa 1998 that will overheat on occasion and blow a couple of tiny fuses on what I believe is the spinner controller board. I get a spinner error when it happens and once I replace the fuses everything may run fine for weeks. I notice that the two large fans at the rear side on the electronic cage never seem to operate. I am guessing that they are turned on by a temperature sensor but I don't know--are they supposed to be turning all the time?
It appears to me that they run off direct power out of the power supply--they are plugged into what would normally be monitor power.
If anyone knows the circuit details for the operation of those two fans, can you share it with me--I would like to solve this overheating issue before I fry a component.
