Dolev 800 Spinner set error.
flrosa
Hello guys.
We have a Dolev 800, with PSM 6.01, and wen i try to expose, i recieve an error "Spinner set error", we already changed de Spinner drive boad, and nothing, please, help me. Sorry about my english, becouse i am from Brazil.
thanks.
Hi flRosa,
I am afraid this problem can be very complicated so it is not so straight forward to solve it.
The following could give you the Spinner Set Error:
1.Fast Power Converter failure
2.Brushless Spinner Driver
3. Spinner Motor Failure
4. Encoder cable
and also the following are Associated with "Spinner Set Error:
HOMC2
CRI
Dynamic Optic Cable.
Good luck.
We encountered this before in our past dol800. what we did was, we manually change the spinner values instead using the auto....it worked.
please check the mirror is rotating manually or not? i mean the mirror in front of spinner motor. or is it stuck?
Dolev 800 spinner set
You have two options to change or reset the spinner driver board It has two fuses push them down or change the board.
This happens when you do not have enough power to run your machine. Your cabling is too small.
Also check that the machine is grounded with a copper tube with some preparation on the side
