Dolev 800V error
  • Thread starter Thread starter kala
  • Start date Start date
K
kala
Guest
HI
Facing problem in Dolev 800v First Machine
If we expose 10 sheets - out of 10 sheets 2 sheets got shrink / expand / overlap.
Sometimes its running perfectly / sometimes continuous error
We changed CRI board / Strobe board.
Machine is running with VLSI + SFL + PSM 7 Spinner speed 10000.
Another Dolev 800V
Spinner Set error / CRI Frequency error
Changed Spinner Driver Board - Additional error Encoder frame warn error.
Spinner tested with high speed / Medium Speed sometimes getting pass sometimes failure.
Anyone help us for both the imagesetters problem.
Regards
HI
Another Dolev 800V
Regards
Kala,
Dolev2.
If you already changed the Spinner board, unfortunately all the errors point to the Spinner.
Did you try the CREI board first?
Dolev1.
Do you mean that the size of the image changes between plots?
Dolev 800v
Dolev 800v
Hi Pach
Dolev 2 :
found that Spinner Driver board is the problem.
Dolev 1:
yes size of the image getting shrink / expand / corrupt / override
Hi Pach
Dolev 2 :
Dolev 1:
kala: getting shrink / expand/ corrupt/ override also happened to my Dolev, try to clean the tiny holes in the dolev drum using needle or something looks like that. Also check the film casette whether the film can be pulled freely. I hope this will help you because it works for me.
