Alith7
Gordo~
so in the "Reflective Value" that is returned, it's measured on a more lightness-darkness scale, versus a chromatic range?
ok.
On the start of the ongoing "To Linearize, or NOT to Linearize" debate...
Linearization of the plate becomes, with the current color management software, an added step that may or may not really have any bearing on calibration. Here is what I understand. When you throw your test patterns on press and then read them into the analyzing software for curve adjustment, the software will adjust the curve to the correct color regardless of if your plates are linear or not. And, when you need to check/tweak your curves, you run a new test patch and read it in again. since you are usually adjusting for environmental shifts, Linearizing the plate first is just an added step that will be accommodated for in the curves anyways.
So, with current technology, Linearizing is basically a wasted step. Took a LOT of debate for me to conceded that.
--->>Thank Alois! Those were really interesting reads!
ok.
