Duplo DC 10/60 system 4000 conveyor belt replacement
Philem
Hello everyone, :)
Does anyone have the procedure for replacing conveyor belts?
Either a technical document or an explanation of what to do and in what order (so as not to turn the machine into a super coffee machine!).
Thank you for your help.
I'm not talking about the stapling module, but the collating tower.
The belts I'm referring to are the ones that are positioned vertically and feed the sheets when they are collected at each station. One of these belts has broken and I need to replace it. The problem is that it seems like I have to dismantle quite a few things in order to replace it, hence my question.
OH the vertical transport belts. Remove the whole assy up at the top cross rod. Lay it on a table and yes you need to remove one side of all those cross rollers. Easy just time consuming. Replace them as a pair
