Duplo to Exhibit Die Cutter & Foil Solutions at Odyssey Expo
prwhite
Staff member
Duplo will highlight its die cutter & foil solutions at the Odyssey Expo—May 1-3, 2019 at the Cobb Galleria Centre—Atlanta, Ga. There will be live demonstrations of the UD-300 Rotary Die Cutter & DFL-500 Dry Coat/Foil/Laminator and the UDM-300 Manual Die Cutter.
Designed for flexible dies, the UD-300 Rotary Die Cutter performs multiple cuts, slits, slit-scores, kiss cuts, perforations and window punches on paper stock up to 14” x 20” at up to 3,000 sph.
The DFL-500 Dry Coat/Foil/Laminator offers an easy 3-in-1 solution to instantly add toner-based digital foil on applications up to 13” x 24”.
