• Happy New Year!
Error Code E4e03 ptr4300s
gkwallace
So, I get the error intermittently. Sometimes I can make 10 plates, other times it takes 5 tries to make one.
Checked laser power, number 29 is bad. Change option to 0-15 diodes and still get same error. It says it's board 3 overvoltage.
Sometimes it won't finish diode test.
Sometimes it says diode 29 is ok
Is swapping boards as easy as it looks?
I've cleaned the optics, can you clean individual diodes?
What should I do next?
Thank you for your time.
gkwallace
Swapped boards 3 and 4 and seems to be working. I was able to make a few plates with all 32 diodes, but then got the correct error that diode 29 is bad.
Runs with diodes 0-15 fine.
I'll keep my fingers crossed.
chock
ok good, error: Excessive current in the LD drive (driver 3 board).
However, i am recommend you , very Strong to test the power supply in tolerances:
1)+5vdc 2) +24Vdc 3) +15Vdc 4) -15 Vdc the tolerance will be 0.5% up or down.
Let me know, sincerely have tech documentation available
Blessing
superchock@yandex.com
Ritchiec
I would check for a floating neutral. Ive had to fit a bunch of isolation transformers to remove this floating neutral. All laser failures and overvoltage gone
chock
ok, let me know, probably the software is Corrupt, and need take measure
for Reinstaling.
Need to make some test-diagnostic, with the service manual
Blessing
chock
Hi sir:
Herre is power filter line:
Number: 20A DOMESTIC 115V - EC-19869 (RP220-20-4.7) or
15A INTERNATIONAL - EC-18896 (DSC1000-4-10-4.7
Merry Christmas
kdw75
Thank you Chock. We are getting the same behavior and the same error as the original poster.
chock
Hi try to measure the input of the machine
Probably the Voltage is NOT o.k, maybe you need install stabilizer in the input of machine, otherwise your will have the same problem.
Blessing
What About Profitability?
Canon 2022
The Video You Really
Need To Watch
View The Video
