Thanks WI-Flexo, I do have some specific questions. As far as file and image preparation goes, do you find yourselves performing the same edits as you would before HD was in place. What I mean to say is are you still taking gradients that end in 0% and adding a min dot out to 1%? Do you still need to edit Photoshop files to breakup the edges of drop shadows and remove scum dots? I understand that in some cases this will still need to be done but I am curious about how much of this will not be a worry anymore.
Also, do you run 100% HD plates or are you mixing these with normal plates as well? Is it necessary for you to run a conventional plate for a change to a legacy job or are you able to replace one regular plate in a 6 color job with an HD plate and still have it work on press? If an old job is pulled from archive that has already been through the normal flexo edits before plating will plating it as HD make any difference at all?
I know, theres a lot I am asking but the price is high and I would like to hear from someone other than Esko about real world production scenarios. Thanks again...
_Tom
