printmagic
We have started special effects unit "Print magic". We have some technical problem regarding pre-press. we have invested in color-logic software to do metallic printing. It has special pallette which has colors that is the combination of CMYK with metallic silver. Now the problem is that the company told to contact any pre-press service unit to set metallic silver as fifth color seperation i.e., spot color. They told that it will be easy for them to set up.
We just give their answer below.
The color-logic Metallic Color SystemTM has been tested and is compatible with most industry standard RIPs and workflows. When outputting a color-logic file, the user outputs in their normal workflow for five color/spot color work. The first time you run a job, you may need to set up the color-logic silver name on your RIP, this is because the Silver separation will not be known to your RIPs lookup table of colors. Adding a spot color to your RIP is an easy process, however please refer to your Administrator or Pre-Press specialist for further assistance.
We don't know how to do this. please somebody help us with full detailed description.
