About a year ago we had a G7 master come to our facility to do the certification process. I am a press operator so I dont want to get too technical so here is my issue. About two months ago our main press operator left (SM52 2006 with pre inking software) and did the re certification for our G7. After he left we have been having a lot of problems hitting proofs. Normal densities that have given us the lowest delta E are C=1.38, M=1.41, Y= 1.03 and K=1.75 (coated inks with gloss aqueous on flo gloss paper). In order to match proofs I have to run K at 1.50, C,M and Y at 15 points under density. Also my prepress tells me that the same curve is applied to all three matte, gloss and uncoated. I am almost positive at the place I worked at before there had to be different curves for each different stock. We are going to run a G7 target tomorrow to try and find where we went bad. Is specta and pretty reliable and predictable dot to use? Also we are using Fuji thermal plates. Sorry cant remember the exact kind of thermal they are.
