It depends on what device you have and what software you have. I have an i1 Pro with Color Picker, so I just input the LAB value in and it tells me if the color is in gamut or out and what the CMYK breakdown is with the ICC profile selected.
In a windows environment how does one check to see if a CIE LAB value is inside an ICC profile?
I have a purple, L*10, A*35, B*-38 which the closest I have been able to get to it is a DeltaE76 of around 20. I'm just trying to find out what is causing the issue. Printer or destination profile. My GRACoL wedge is inside 12647-2 so I assume it is out of gamut but it is also a pretty simple CMYK build.
This is off a digital toner based press. Sequence is Y-M-C-K.
You can still download the entire ProfileMaker toolkit. It won't run on a Mac OS newer than 10.6.8, it will still run under Windows.
ColorThink is a great way to visually examine why a color may not reproduce. I've uploaded an image of your target color plotted against the gamut of GRACoL_2006. In the screen grab, your target color is the white dot. It's really dark and really saturated.
You're not going to be able to print that color.
Greetings, you can use the attached file to check a color in ColorThink grapher. Just open in excel, or any text editor, and replace the labxyz values with the values of your color, then add to Plot Items box in ColorThink grapher.
