This rears its ugly head every now and then. Had a customer complain about it today again. I see it in grayscale mode a lot but this job was color but with black only elements set to CMYK gray prints a black only. Rows of description and pricing alternating between 20% and 0% fill. Black text looks like it is bold on the 20% fill and regular on the 0% fill. With CMYK gray prints a black only turned off it does not do this. Raster view in ImageViewer does not show any difference, so it is something with the engine. I can find some settings like setting Text/graphics quality to normal or different screens will make it less noticeable but nothing RIP setting wise seems to totally eliminates it.. Or course if you use 1% fill in the white row the text looks the same other than the optical illusion you get which I can confirm looking at it through a loupe. It is almost like because of this optical illusion someone decided to program the print engine to choke the text on fills but made a mistake and spread it instead. And by the way Trapping on or off makes no difference. APPE on or off makes no difference.
Maybe I am overlooking a setting that is causing this? has anyone figured settings that will not cause this to happen?
I had time today and took this issue to second level. It will be interesting what they come back with. I also have my tech looking into this. Engine setting, NVM setting somewhere maybe?
