"Then he was instructed to increase the density of the Magenta to the max - which in this case was plus .20 points. This is a density that would never happen in actual production."
Wow, this is an amount I routinely see our pressman LOWER the densities, DURING actual production.
I don't know if you're joking or not. Because if you're not then that kinda blows your whole G7 color management story below.
Usually press operators lower SIDS for good reason - it might not be the right thing to do but, given SIDS are basically their only control that's what they do if they're trying to match a proof. Usually lowering the SIDs to match the proof is because the plate curves aren't appropriate.
I will say that I've never thought of the 3C gray patch as a means to monitor SIDs but rather a way to monitor gray balance, TVI shifts, maybe even plate problems?
In newspaper work it is not unusual to see the GB patch used to indicate SIDs. I've never seen the GB patch used for monitoring any of the things you noted. It is sometimes used forensically after the run is done - not during the run if the job is failing.
I disagree for all the reasons I've already covered.And if it is way more sensitive to changes than the live image I would see that as even more valuable because I would think that if you can keep that patch balanced, the live image will stay well within tolerance.
If we are printing with G7 method, we've created curves to bring the gray into balance across the scale, then isn't the 3C gray patch just as important for TVI reasons? Solids are ran to the densities determined to give the best Lab match to what is called for in the profile, plates are made with curves which only deals with dot size put down on the paper, then how do you check TVI to make sure the press is still in line with the curves you're applying to the plates? 3C gray patch gives you instant visual and measurable data on whether your print is still aligned with the day the curves targets were ran.
Maybe, maybe not. A color bar on a live production job does not have the same value as a test firm which is carefully layed out to compensate for how presses lay ink down.
I know you're not a proponent of G7 so there are really 2 angles to this thread. Coming from the G7 angle I see it as invaluable.
My problem with G7 is related to how it was tested and brought to market. Lot's of decisions based on authority rather than scoence.
You are trying to demonstrate to the pressman the same thing, consistency, measurable consistency, so that when the press is started up, ran to target SIDs, with the right curves on the plate, color will "fall" into place. That is what we see here using G7 but I'm sure this isn't the only approach that will produce that.
I thought you said the pressroom was lowering SIDs to match the proof? ;-D
Consistency is the key. Plates can be produced very consistently, press work inherently varies more so. If using G7 method with that profile, curves applied to plates, press is ran to target densities and tweaked to gray balance if necessary, color does fall into place, or in other words, matches a proof made with that same profile really well.
I agree, and it works even if you don't use G7.
There are always some colors that don't match exactly and sometimes some that don't match very well. It's often a compromise of some sort as to dialing-in what is on any particular sheet depending on what is in-line with it around the cylinder. Color matching on every run depends on what colors are in the live work and how well the complete process can reproduce those colors.
Yes.
The bigger part of this to me, has been getting the pressman to buy-in. Even though he has seen it work, he still views it as a craft type of job and turns each run into a custom adjusted one. This of course causes problems, as you would know, of having much more inconsistency in our print jobs over time, from week to week, month to month, year to year.
Given that we are printing volumes of books with same cover photos, color indexing and backgrounds, year after year. Also makes for 3-5 hour make-readies and thousands of sheets used. IF you can figure out how to convince people to change, that it WILL actually be an easier way, AND save time and materials, then you will really have something! Please let us know when you get that one figured out![]()
There are ways to get the press guys on board which I've covered earlier.
Great discussion. Really interested in Auraia screening also, let us hear about any further testing or results you get on that.
So far they love it - no problems, but I will be going more in depth with them on the screening this month.
Best gordo
