Hamada B 52 SF Blanket Jam
cramada
Hi
We are using our Hamada B52 SF and every time we feed the paper it goes in to the machine and before it starts to go round the blanket the drive shuts down and the machine flashes the error "Blanket Jam", what we think is the sensor for this seems fine - Any ideas?
For what it is worth I posted here about my problem with a DU 34 II that will not detect blanket jams even through the sensor appears to be working.
Your issue sounds like maybe the sensitivity needs to be adjusted. I know on my DU 34 if the sensitivity is incorrect the press will shut off every time I stop the paper feed. I can fix that. Now if I could only get it to detect a real jam....
