Browntrout79
Having an issue with ncr paper sticking to blanket.
Usually the yellow sheet. Tried various blanket pressures and no luck. Usually it's on the larger ncr sheets. 11x17 8.5x14
Don't think it's a static issue, moved the job to 3302 and is running fine.
Blanket is clean, in good shape, with pressure at 0.15
Thought may be a gripper issue, but other large stock runs fine. Including
60#.
Thanks for the help in advance.
60#.
