Heidelberg SM74 CP2000 PresetLink CIP3/PPF Setup Help
ezequiel
Hi everyone,
I recently acquired a Heidelberg Speedmaster SM 74 from 2003 with CP2000 console. The press has both PresetLink and ManagementGate licensed/active.
I’m trying to load CIP3/PPF ink preset files into the press using .ppf files generated by PressPercent, but I honestly don’t understand the correct workflow to make the CP2000 actually receive and load the job data.
So far:
  • I already assigned a static IP to the press
  • Network connection is working
  • I can generate .ppf files
  • But I don’t know how the files are supposed to reach/import into the CP2000
My questions are:
  • Does PresetLink monitor a network folder automatically?
  • Do I need additional Heidelberg software between prepress and the press?
  • What exactly does ManagementGate do?
  • Was this originally designed for network transfer or external media/cards?
  • Has anyone successfully integrated a CP2000 SM74 with a modern workflow?
  • Is there a specific folder structure or filename format required?
My goal is basically:
PDF → RIP → PPF → SM74 automatic ink preset loading
Any real-world experience with CP2000, PresetLink, CIP3/PPF, or Heidelberg integration would be greatly appreciated.
Thanks!
