Heidelberg Topsetter 74 error E41c0
jmandassociates
Looking for some help with a Heidelberg Topsetter 74. We are getting an error code E41c0: lead clamp release bar cannot be driven. Either PH30H or PH31H.
aligh
hi
about your problem ,ph30h ,ph31h sens open /close leading edge clamp in home side.
h means home side(toch screen is home side)
ph30h for origin point and ph31h for end point of leading edge clamp
open the back door of the topsetter , you can see leading clamp .in home side of leading edge clamp you will see
ph30h and ph31h if sensors be ok (not damage).for one step please clean it .clean middle of two(ph30,31h) sensor (gap) carefully.
close door and run your job if the problem not solve
second step is adjusting. you have to open service menu
do you have password?
test one step and reply .if give error i will explain next step
regards
Femstar
Hello Looking for some help with a Heidelberg Topsetter 74. We are getting this error code E420f: recording head has not been positioned at its origin. ( origin sensor does not turn off.)
Femstar
Femstar
Hi thanks for the reply, I have removed and reinserted the sensor cable but we still getting the same error massage. Please help.
