Help_Kodak_Magnus 800
Lord
Hello to you.
We have a annoying problem with our platesetter, we have a Kodak Magnus 800 that gives increasingly often this error:
The exposure failed. Rcon error: Error Code [03557] System: the +3.3V is out-of-range(Error code : 44300, Error categorie =07-fatal error, device cannot recover) Click Unload to automatically unload the plate from the drum. Restart the workstation selection.
All your suggestions on the cause of the problem will be become. Thank you in advance.
Rcon errors are often related to the Local 3 card.
Does your machine have 2 Local 3's? If so, swap them around and see if the error changes. if it does, you have a bad Local 3.
the laser is the issue but not the focus - that is a 3.3v internal converter error
If your lucky, it could just be the cable
There is no Local 3 card in a Magnus 800.
