How to, Apogee Prepress colour management?
Hello, I’ve been searching for answers to my colour management questions; but haven’t found anything yet.
First I would like to give a little background, I run a commercial newspaper print shop and I am trying to work towards the ISOnewspaper30v4 specs. I am trying to find out how to set up my Apogee Prepress workflow (v5).
Here’s what I have done so far:
Generic Press Task Processor -> Color Profile -> ISOnewspaper30v4
PDF Render -> Generic Press Settings -> ISOnewspaper30v4
I don’t have a clue on how to set up the PDF Render:
PDF Render -> rgb -> images:
Untagged (No Profile attached): ?
Tagged (Profile attached): ?
Default ICC Profile: ?
Rendering Intent: ?
Black Point Compensation: ?
Device Link Profile: ? I am assuming that I don’t need a device link profile because I am using the ISO profile in the Generic Press Task Processor
I have the same questions for the, Gray, CMYK, Spot & Document settings in the PDF Render Task Processor.
Thanks,
JP
PS: I just ordered the Real World Color Management book from Amazon.
Untagged (No Profile attached): sRGB (would be the safe assumption)
Tagged (Profile attached): Use profile (otherwise you are changing appearance of work)
Default ICC Profile: sRGB
Rendering Intent: Preceptual (since you are going to a small gamut)
Black Point Compensation: (ok to check, but has no effect on persceptual)
I have the same questions for the, Gray, (this depends on what used to be standard in your region)
Untagged (No Profile attached): I susspect gamma 2.2, but won't swear by it (would be the safe assumption)
Default ICC Profile: As default
Rendering Intent: Relative (since we want black and white points to be maintained)
Black Point Compensation: yes
Untagged (No Profile attached): I'd set to sama as default (same effect as preserve values)
Default ICC Profile: OutputIntent
Rendering Intent: Relative (since we want pure colours to be breserved and white points to be maintained)
There is also an option for exceptions and I would preserve pure colours. And more important to preserve black.
Spot colours can use Absolute colometric and peserve paper white.
Think that covers it ;P
Thanks for the answer Lukas. : ) I'm going to run some tests through your suggestions Monday and see what I get!
I'll leave a note on what I've found!
Cheers,
JP
PDF Render
Rgb Images:
Untagged: use default profile
Rendering Intent: Perceptual
Black Point Compensation: Yes
Line Art settings follow Images settings: Yes
Generic Settings:
Destination Profile: ISOnewspaper30v4
Advanced CMM: Yes
Overprint Settings:
Honor application settings: Yes ?
Gray Images:
Default ICC Profile: 2.2 gamma (where do I find this profile?)
Rendering Intent: Relative colorimetric
Generic Settings:
Destination Profile: ISOnewspaper30v4 (or ISOnewspaper30v4_g if possible)
Advanced CMM: Yes
Overprint Settings:
CMYK Images:
Default ICC Profile: ISOnewspaper30v4
Rendering Intent: relative colorimetric
Line art settings follow images settings: Yes
Generic Settings
Advanced CMM: Yes
Overprint Settings
Spot
Conversion from application values: treat as CMYK input?
Conversion from books
Accurate spot color mixing: Max 3 colors
Use document profile’s paper white: Yes
Generic Settings
Advanced CMM: Yes
Overprint Settings
Document
Document Profile
Untagged: use destination profile
Document rendering intent: relative colorimetric
Generic Settings
Advanced CMM: Yes
Overprint Settings
Also where and how do I change the exceptions options to keep pure colours? Is it under Generic Press -> Colour Books? What does this option do?
I also have a few more questions but, I'll take my time with asking them! lol
Cheers,
JP
Was hoping somone from newspaper could come with their insights. I will leavi it a little longer and then I will answer if no one else does. The exceptions you will find in via the QMS application.
