I need help in numbering tickets
2mira
I need to know how can i reach to this numbering style
number 1 : in first page up
number 2 : in second page up
number 3 : in third page up
and sooo on
Give this software a try. http://marcom.com/fusionpro/fusionpro-vdp-creator/
This allows you to setup your numbering. You can have padding with 0's so if you have 10000 tickets your #'s would start with 00001 and progress through 10000. You will also need FusionPro Imposer that will allow you to impose them as multiple ups & stacked as needed to keep the number ordering straight.
Good luck!
There are many ways to do this, You can use the header and footer to put in numbers, or cute pdf a $50 program I have been trying to fire for many years. After the pdf is numbered you can use the stacking option. I think cute even has bates plugin that I have not used.
You may want to check out Number-Pro. It works with any desktop publishing software like Indesign, Word, Publisher, CorelDraw. Any desktop publishing software that allows data or mail merge functions. Great for numbering raffle tickets and NCR forms on your digital printer. http://www.number-pro.com
