Re: ICC software
Hello Flexonaut,
You can likely accomplish this with almost any pro ICC solution. From GMG, open your mx4 and export your measured data. The resulting text file will contain both your index (input values) and your measured Labeez.
If you are using a TC3 or TC4 (or other GMG-specific) target, you will need a CM app such as ProfileMaker, PerfX, or EFI - that can use a set of arbitrary sampling points to build a profile. If you are using a standard target - such as the ECI or IT874, then you can also use MonacoPOFILER.
Whatever app you choose, locate or create a sample text file that you know will work with that app. The rest is basically "Excel-manship". Open the GMG export file in excel (you will need to select a delimiter for the ";" character). Make sure you select open from Excel and do not drag and drop. Otherwise, you won't get the text import wizard.
Once you have that open, open your sample file and check out the differences. It should be immediately apparent what you need to do. Another note, when making a CGATS-style header (if you need to do that), the format is as follows:
Begin_Data_Format
<data column names>
End_Data_Format
Begin_Data
<actual data, includes input and measured values>
End_Data
You may see a lot of extra junk (in some file formats). Don't worry about it. Chances are that you only need the data pieces.
Hope this helps,
Marc
