also looking for a firmware update for this.Hi, I have an iJetColor Pro. When I try to print, I get an error message stating "IR Tank Level is too low. Cannot start Print". Anyone have any insight into this? I've used lots of memjets but pretty new to the ijetcolor pro.
Hi Scotts, thank you. yes I have tried all of that. It looks like one of the boards on one of the reservoir tanks is malfunctioning. I replaced one last week that was completly dead, It is now back to showing levels but the yellow is reading lower than it actually is. What is now confusing me is why does it care if its "too low"? they are all showing that there is some in each tank.I haven't run into that error before. Have you tried a complete shutdown, powering off, and unplugging the press? If that doesn't work, one of the sensors used to measure the ink may be dirty. I would shutdown the printer and then take out each ink cartridge 1 by 1, and see if there is a sensor in the back, if so, try and clean it with a link free cloth or cotton swab.
