Hi hansman,
as far as i know CS4 installs its own versions of fonts which are not back compatible(not usable with CS3-2-1), dont know which ones but i guess Minion, Myriad... etc. Do you use one of them? If yes i suppose if you change them with other fonts not 'updated' by CS4 the document should be OK after saving it as .inx. I know it's not a perfect way but cant figure other one (
As with any programme, files should not be back saved to a previous version. If you do you WILL expect problems.
Trade Gothic is not an Adobe installed font.
That being said, letts go back tho the initial problem you ask if there are problembs (general), but you do have a specific problem. Let me clarify.
You have problems with a document containing Trade Gothic converted from CS4 to CS3?
Do you use CS4 and CS3 on the same computer (physical)? Is it on the same platform?
Yes OS X.57
Do you use font management software?
Yes Suitcase Fusion
Do you have exactly the same font and font version, including afm files if you are useing metrics kerning?
Yes Same Mac
