Had a same problem with our ryobi 3304 turned out our fount solution was out of date … and the ink was too runny replaced the solution and an h changed to best one inksView attachment 291393Hello folks, i've been having this issue with mostly magenta and reds, after a short run (2,000-5,000) we get ink in areas where there should be none and also in small text areas. Is this plate blinding or what is this called? We think it might be conductivity and/or pH related. Any feedback is greatly appreciated!
It could be a calcium issue, rinse the unit up and run some calcium cleaner in for about 10 minutes, rinse and use hot water, then run some febo clean paste in for about the same amount of time and rinse again, if you run a lot of uncoated substrates this happens often. Good luck.View attachment 291393Hello folks, i've been having this issue with mostly magenta and reds, after a short run (2,000-5,000) we get ink in areas where there should be none and also in small text areas. Is this plate blinding or what is this called? We think it might be conductivity and/or pH related. Any feedback is greatly appreciated!
Maybe we could discuss the 5 Ws of the need for the repair, in the first place. Hmm?I attribute its long life to the fact that I used a slow curing 2 part epoxy.
The need for the repair can be attributed as far as we were able to tell ,to some sort of foreign metallic object within the paper pile.Maybe we could discuss the 5 Ws of the need for the repair, in the first place. Hmm?
