Isolated transparency groups
pol007
I'd like to know if there is possibility or some kind of workaround in Pitstop to select only isolated transparency groups.
It's not possible at the moment, but it's not difficult to implement.
The team are interested to know the use case behind the request, can you share?
My workflow cannot render properly patches X and Z from Altona Test Suite 2.0 so I want to detect potential problems in incoming files and reduce false alarms. Also special spot colors (dieline, varnish...) won't overprint when they are part of isolated transparency group (they overprint only objects inside the same group).
