The company has purchased 2 Kodak Gen News V speed. They are 1200 DPI machines. Will we be able to output a 133 line screen?
Shediac - because we use a 5000dpi SQUAREspot imaging head to achieve 1200dpi output resolution, we draw those dots EXTREMELY precisely. This allows us to support up to 200lpi hybrid AM screening at 1200dpi, or 36 micron FM screening.
Of course, this is also dependent on the plate you choose, but 133lpi is no problem on most thermal newspaper plates.
Kevin.
I have to disagree with Kevin on this one.
Shediac is likely concerned about achieving all the grey levels needed for 133 lpi screening on a 1200 dpi device.
The classic formula to determine grey levels is:
(dpi/lpi) squared + 1 = number of grey levels
So for 133 lpi at 1200 dpi:
1200 dpi/133 = 9
9 squared = 91
91 + 1 = only 92 possible tones
However, since about 1985, Supercell screening (a function of the RIP not the output device resolution) has eliminated the grey levels limitation by "dithering" the halftone dots. This type of conventional AM screening is available, if not the standard, from all the vendors - including Kodak.
More info here:
Quality In Print: Halftones and grey levels - part 1 of 2
and here:
Quality In Print: Halftones and grey levels - part 2 of 2
best, gordon p
Thanks Kevin. When you say hybrid AM screening you mean?
To get technical, 9 squared is 81.
The point being, we support 200lpi on the device he mentions, so his need for 133 is certainly met. My point about SQUAREspot enabling 200lpi in a robust, consistent manner on a 1200dpi device stands.
Kevin.
Gordo, now I'm a bit confused. Does this mean we have to purchase different screening technology from Kodak?
Kevin.
Could you elaborate? Are you saying that other vendors can't deliver 200 lpi on a 1200 dpi device? What do you mean by "robust"? Do you mean that other vendors can't deliver 200 lpi (or 133 lpi) consistently on their plates?
j
