Komori picture framing
"Why would you replace Komorimatic Dampening System, which is one of the finest press dampening systems available, with the patented Epic's Delta Dampening System ? "
Komori, in their wisdom, adopted a gear driven form roller on the KomoriMatic in order to drive the form roller at a speed different than that of the plate as opposed to being surface driven by the oscillating chrome roller. Many people consider this a positive development, but I have seen considerable performance improvement in many cases by removing the gears, essentially returning the dampener to its pre-improved state. There have been a considerable number of Komoris in the US retrofitted with Epic Dampeners and this I am sure influenced Komori's thinking, as no one in the printing industry would ever spend large amounts of money foolishly, would they?
We have continuously used Komori's since 1992. We have tried taking the gear off of the water form and all it does then is picture frame. We put the gear back on and it goes away.
You can also turn picture framing on and off with the type of fountain solution and inks used.
We also tried distilled, Ro, filtered, or tap water it doesn't have any effect on picture framing when the correct chemistry is used.
