I have a KM C550 and am having trouble with image skew. I have run the Fiery tray alignment and the points that it deals with are lined up ok. However, The image is skewed enough that the alignment of other areas is out by up to 2mm front to back.
Specifically, when viewing a landscape 12x18" sheet, the horizontal lines are parallel to the edge of the paper. This tells me the paper is going through straight. The vertical lines are not parallel to the ends of the paper. They look like this |\\\\\\\\|. When duplexing, the error is magnified because each side is off in opposite directions (when viewed on a light table).
There is a skew adjustment in the setup area, however it only adjusts the CMY. There doesn't seem to be a way to adjust the black. The CM and Y are in register with the black. This would seem to indicate that the whole imaging unit is cocked and is not perpendicular to the imaging drum or belt. Is there a way to physically adjust this in the machine?
Also, there is a slight size difference from front to back. The back seems slightly smaller. There doesn't seem to be a front to back size adjustment either.
Thanks,
Thanks,
