Konica Minolta C8000 feed issue
Roger4
Hi
I have a Konica Minolta C8000 with the PF705 installed (I think). Sheets load to the separation roller then stop. Any ideas?
ally170
Have you checked the gears at the back of the trays? There are plastic gears which we have had experience of teeth shearing off and jamming sheets.
How long have you had the c8000?
jwheeler
Are you running a material that might have a lip to it...like label stock, or magnetic material for instance? If so, make sure you turn off "Double Sheet Detection" in the paper tray settings on the machine panel. If it's just regular paper, then you might need to have service check the double sheet sensor as it could be mis-reading.
