We are using a C8000 with creo for about 4 months now. Overal pretty happy with the colours and speed when it runs properly. Have a couple of issues though and need to know if this is a machine problem worldwide or something messed up by the engineers who set the machine over here in India.
1. The density of black is a big problem. If I print a job which is 100% black on coated paper it does not come out very dense (very bad if I compare it with my C6501), but that problem is not there on uncoated stock. Also, the density worsens over the length of a job. If it is a run of about 200 prints that 100% goes to about 80%. If it is a 4 colour image or vector with a lot of black the same problem occurs over the length of the job, but this does not happen with the other colours.
2. There seems to be some problem with the IBT cleaning blade assembly. Whenever we run a large job on 100 gsm coated/uncoated paper, waste toner scratches start coming on the print say after 3k-4k prints. If we stall the machine for about 5 mins a few hundred prints come fine and then the same problem. When we removed the assembly we could see toner formations above the plastic scrapper at the same positions where we were getting the scratches.
The black density issue is really creating a lot of problems and we are loosing quite a few jobs. Can somebody recommend anything !
Thanks,
Pratik
