Dear sirs!
I'm looking for a Laconda B2 manual. Machine is 2009.
We can't run it in continuous mode. It does inching (moving until start button is pressed) and 1-cycle mode. May be there is 1 value to be added into the config interface.
Hi sir
Normally when this happen, the inching button is dirty, try to clean it 2) see if they are loose wires, or corroded, or connector dirty, clean it very well. and replace it, if necessary.
2) clean all Edge connector of electronic board, for corroded, and loose wires,this is most main defects in electronic troubleshooting.
