margadri
Since we started using Trillian, plates we are having problems with the paper sheets between the plates not getting "grabbed" by the grippers and causing the Lotem to error out. Kodak engineers are out on call almost every second day to try to fix the problem. Changed the rubbers for the grippers, played around the "force" the gripper use and so on. No happiness so far. Only solution is remove manually the paper between plates thus increasing the possibility of two plates getting stuck together. Some batches of plates are worst than others. Has any of you ever had a similar problem or is just us who are soooo lucky. Thank you in advance
Edit: Kodak supplier replaced the batch of plates with new one.
They seems to have less problems with the paper.
It appears that the paper between plates was upside down, meaning that the waxy glossy side was exposed and the rough side was on the plate. When gripper tried to grab the paper, were finding a slippery surface and weren't able to have a proper grab. Still find it hard to believe but that is "one" explanation!
Wierd!!!
Wierd!!!
