K
kala
Guest
Hi
if i give xy in harware iam facing the below mentioned error:
error 1:
DC Motor HP messing or Disconnected.
The task centering motor Go HP detector failed.
The task xy initialize of loading system failed
if xy works sometime then iam facing the below mentioned error
error 2
Centering motor task didnot end
The task centering motor go pos failed.
The task load from casette to punch entry loading system failed.
The task load from punch entry to drum entry loading system failed.
We tried changing the hp sensor on left hand side near centering motor. ( we changed the belt last week and adjusted it last week this is fyi its working fine past 1 week)
Under hardware/loading system system/centering system/ centering motor - if we give position or distance its not working if we give HP Det we are getting the below mentioned error.
Under centering motor / centering motor home position detector status is default on
Under centering motor / centering motor plate short detector status default off.
We adjusted those two bars manually and hold it then centering motor plate short detector status default on and if we release our manual hold then it shows off.
Under detectors we found some of the status off & On
Like Bar flage 1 detector - off
Bypass casette line detector - on
bypass casette outside detctor - on
bypass lock hp detector - on
dc tray button detector - off
paper/metal det - on
plate in punch short detec - off
xy vaccumok detec - off
xy vaccum power on dtectective - off
regards
kala
error 1:
error 2
regards
kala
