You should be able to turn the punching off in your workflow.
If you're exposing through Xpo, change your templates to not include punching
If you use another workflow, there will be a setting for punch type
I tried unplugging the punches, Lotem just stops and gives an error. I also deselected punches in Xpo but still get error about punches.
Where is it in Lotem software to turn off the punches on the Lotem. I can't locate it.
Go to Utilities>Hardware>Punch system>Punch system i think you can turn it off from there or try Utilities>Hardware>Loading system>Loading system>Select punch for loading, hope that helps
We were able to remove the punch and give it some TLC with a grinder to get it moving again. So far so good.
(Never did get the punches to turn off though)
We never had to resort to anything that drastic.
Aligning the detector usually fixed problems.
BTW, turning off the punches altogether may probably be done in the registry but I don't remember details.
