metallic effects and/or boosting vibrancy
Gordo you read my mind; I am looking for that special sauce receipe. Mirafoil is something interesting that I would like to try sometime, but not what i want now.
For silver included in images - you'll need to build the 5th plate manually in PShop just as was done preMetalFX.
So the designer would create a 5th channel layer for that image, and choose where the metallic effects are to be placed.
My questions here would be
1) Should it be solid silver? of halftone? is there a certain kind or brand of silver that would give a better shine?
2) The ctp plate should go on the first unit same like mfx? and low densities?
For hexachrome, I assume you mean boosting vibrancy in images - you build a "bump" plate manually in PShop using whatever color you like/need - orange, red, violet, blue, green to expand the gamut in that area.
So the designer would create a 5th channel layer for that image, and based on how dark the color is, it is set on the approriate press unit.
1) Can color be simulated on screen?
2) Do I have to print a custom 5 channel chart, print it on press, and create a custom profile using profile maker for example? and is there a way to convert rgb images to this 5 channel profile instead of cmyk?
3) How about the densities at print?
4) will this be solid or half tone? i am guessing half tone and solid where needed
While doing my research I came across a link where the auther explained substituting one of the primary colors with a metallic one similar to it, like gold for yellow. Anyone has tried this?
The link to the website is
http://www.edliveshere.com/content/metallics/4/combining_metallic_inks_with_color
I thought i would mention it although as of now i can't access the site, but if you google "combining_metallic_inks_with_color" then click on "Cached", google will show you a cached copy of the article.
