RV.10.0What version of freeflow is it running?
no they are all gray this is an EA 120Are the center lower doors blue?
Thanks for your response! Do you have a booklet maker on the Varioprint or just a stacker? Does it print glossy stock well? Thank you in advance!We have a Canon Varioprint 140. It is amazing. We use it for book production. We print mainly 11x17 and 12x18 20lb. Halftones and solids are beautiful.
If you use friction-fed bindery equipment might have some scuffing issues.
Can I ask, what paper is it picky about? We mostly use 12x18 80# gloss text, and 12x18 60# uncoated, plus 11x17 60# uncoated, and anything from 20# text to 80# cover. We typically use Cougar, Blazer, and Lynx. Thanks in advance for your responseI service the canon VarioPrint. Great machine. Picky about paper too. Otherwise a million between calls isn't a problem. TTF belts need to be replaced after a million though
We have a continuous stacker. It holds 6000 sheets. It prints 3000 sheets and the tray moves out and printing continues. It does print on glossy stock.Thanks for your response! Do you have a booklet maker on the Varioprint or just a stacker? Does it print glossy stock well? Thank you in advance!
Sorry I didn't respond. It's mainly the amount of glue in the paper that's a problem. There's a listing of recommended papers available. What would happen is glue getting into the drum and requiring cleaningCan I ask, what paper is it picky about? We mostly use 12x18 80# gloss text, and 12x18 60# uncoated, plus 11x17 60# uncoated, and anything from 20# text to 80# cover. We typically use Cougar, Blazer, and Lynx. Thanks in advance for your response
Revolutionizing Layout Planning and Automation InSoft Automation announces the launch of Imp Version 14, the latest iteration of its industry-leading cost-based layout planning software. Packed with cutting-edge features, this release redefines efficiency, automation, and workflow optimization for printing and finishing processes. Learn more……. |
